  • Guests: 35
Nicko (56)
04/19 Nicko (56)
04/20 gentoo_daemon (42)
04/21 kilovolt (49)
Winding a MOSFET gate circuit transformer for a 4046 PLL SSTC
tarakan2
Sat Aug 22 2015, 04:47AM Print
tarakan2 Registered Member #3859 Joined: Sun May 01 2011, 03:47PM
In a circuit like this, how should the transformer that drives MOSFET gates be built?
In the past I made a circuit that didn't work because I used a wrong ferrite ring.
What ring am I looking for and how many windings of what wire diameter?
Do I need to rectify the power input with a diode, considering that I live in a 120VAC country? Is this diode mission-critical?
Thank you.
Robert2
Sat Aug 22 2015, 09:06AM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
"Is this diode mission-critical?"
Yes.
"how should the transformer that drives MOSFET gates be built? "
Use the 3E25 or 3C90 ferrite materials toroid. The dimensions of toroidal core are TN32. Buy TN32-3E25
Justin
Sat Aug 22 2015, 01:10PM
Justin Registered Member #46164 Joined: Wed May 07 2014, 08:16AM
Since the HvWiki is down this is a good place to start.
tarakan2
Sat Aug 22 2015, 04:50PM
I looked at the datasheets, I am shopping for a TN32/19/13-3C90 core,
Or a 3F3 core.
My TC will not be a very high frequency one. Maximum of 1 mhz. I am aiming for less.
tarakan2
Thu Aug 27 2015, 11:15PM
Ferrocube is a UK product that isn't cheap in the US. Is there a cheaper alternative that is less than $20 that can work as a gate driver transformer ring within frequency ranges given?
Thank you.
dexter
Fri Aug 28 2015, 05:47AM
for high frequencies and for small gate capacity transistors you don't rly need such a big core...
for regular TO247 IGBT/MOSFET's i use max 25mm outher diameter cores
here's an alternative for US Link2 i ordered a few of those but didn't had the time to build the GDT's yet...
tarakan2
Fri Aug 28 2015, 07:12PM
The core 495-3862-ND Link2
offers A(L) of 4620 nH/turn
while 3C90 and 3F3 offer A(L) of about 2000 nH/turn.
A(L) - A subscript L - that is nanoHenries or microHenries per turn of wire.
Looks like this value is twice as big for the new toroid you suggested. There is no frequency range mentioned anywhere in the datasheet.
So the question is still open. Thank you for help though.
Thank you. Can I replace IRFP250 s with some more powerful MOSFETs in this circuit to make it more suitable for higher currents? I live in teh United States and we have 120VAC here - therefore more current will flow through the primary to do the work. What replacement upgrade MOSFET would you recommend?
201 Thank you!
tarakan2
Sat Aug 29 2015, 01:43AM
What GDS toroidal core is used in this project: Link2
Justin
Sat Aug 29 2015, 05:26AM
tarakan2 wrote ...
"Its a N30 material ferrite toroid, properly around 30 mm in outer diameter. Find one with a permability above 4000."
Read the page comments, you can find lots of information there.
tarakan2
Sat Aug 29 2015, 05:39AM
Halfdead wrote ...
tarakan2 wrote ...
I read it but is it a circuit author who is answering? Is permeability more important or uH/turns?
The toroids on DigiKey with permeability of 4000 are expensive, large and it looks like they aren't for GDT purposes.
Why are there so many circuits that use GDT and so little informetion about how to choose ferrite cores for them?
Thank you.
