  • Guests: 33
gentoo_daemon (42)
04/20 gentoo_daemon (42)
04/21 kilovolt (49)
04/21 wannabegeekTC (49)
Adding another NST. How should I reconfigure my MMC?
crashstudio
Tue Aug 11 2015, 09:39PM
crashstudio Registered Member #54484 Joined: Sun Feb 15 2015, 06:18PM
I'm adding another 15kv 60mA NST in parallel with my existing NST same make and specs for 120mA.
TeslaMap suggests an LTR of 34.3nF. The MMC calculator suggests 2 strings of 9 to = 33.3nF at 18kv peak. The peak voltage of my 15kv NST is 17.12kv. Is that a safe enough range or should I go with 3 strings of 13 to = 34.6nF at 26kv peak? And what do you believe the best capacitance value would be?
If I go with 3 strings of 13 I'll have to purchase more caps to provide tap points of less value. Right now I have 40, I'll need 48 total to provide a total of 4 taps. 34.6, 32.1, 30 and 28.1. According to the calculator.
Also, TeslaMap suggests a PFC cap of 322uF.
Can I use these from ebay? Link2
Coil specs:
NST X 2 (both are Franceformer with GFCI circuit removed)
* Input 120v
* Freq 60Hz
* Output 15KV
* Current 60mA
NST Protection:
Terry filter
Richard Quick static gap. 6" PVC with 11 pieces of 3/4" copper pipe all spaced at 1/32"
Primary Coil
* Diameter .25"
* Spacing .25" roughly
* Center hole diameter 6"
Secondary Coil
* AWG 26 magnet wire
* Height 20"
* Coil form 4"
Toroid 4" x 17"
Thank you for your help
Wed Aug 12 2015, 08:57PM
Been a while since I built an NST coil, but my recollection is that you want the MMC to match the transformer impedance at 60Hz. this will give max power transfer to the tank capacitor. If my calculations are correct you need about 21nF for MMC. Depending on what types of capacitors you are using, you can figure out the series/parallel config to give the right capacitance. Hope this helps.
crashstudio
Thu Aug 13 2015, 01:52AM
I believe your calculating the resonate capacitance. From what I've learned NST's prefer a larger than resonate capacitor (LTR). The coil will perform better and it will help preserve the life of the NST. I was just asking if an MMC with a max rating of 18kv is safe enough to handle the peak voltage of my NST which is 17.12kv.
Thu Aug 13 2015, 07:41AM
crashstudio wrote ...
All MMC design is a trade off between life time and price. For a very long time the DC rating of a pulse capacitor have been used, despite we really should find the proper RMS voltage vs frequency in the datasheet and derate our capacitors accordingly.
We rely a great deal on the very short on-times, intermittent use and that our coils might sit for years without running and over a life time it might not see more than a couple of days of combined use.
Is your MMC good enough for hobby use, yes(until it explodes). Will it survive running 24/7, no.
Signification
Thu Sept 10 2015, 02:20PM
Isn't the peak voltage of a 15kV NST Vrms*sqrt(2)=21,215V ? Additionally with the variac (o-140VAC input) multiply this product by 140/120 yielding just under 25kV.
What calculation gives you 17.12kV, I may have something off since I never used an MMC.
GrantX
Sat Sept 12 2015, 06:01AM
I believe you are correct, Signification. However, the spacing of the spark gap *should* limit the maximum voltage the MMC sees.
I've somehow managed to kill a cheap 24kV MMC with a 8.4kV transformer, even with a very conservative gap spacing (to be fair, they weren't suitable for high pulse currents). Your mileage may vary...
Signification
Sat Sept 12 2015, 10:59AM
Sounds like non-equal energy sharing somewhere.
