  • Guests: 18
Intra (36)
07/03 Intra (36)
07/04 Krautesh Vakir (43)
07/04 Aziz Efendi (38)
Triggered spark gap success
Kizmo
Sun May 03 2015, 08:48AM
Some time ago i found this post and decided to give it a go myself: Link2
1430642064 599 FT0 Scema
I don't have any construction pictures but here is one of the higher energy test shots we did. Bank was charged to 1380V and discharged through soda can. After firing bank voltage was reading about 150V so energy released was about 29.5kJ
We performed several, maybe 20 shots at different energy levels. What i really like about this gap design is that it fires at any main storage capacitor voltage. Even all the way down to like 20V. It fires instantly, and i can use very safe gap spacing. Triggering is simply done by turning on the 12kV power supply, which is just rectified NST and BOOM.
Here are some aftermath photos from last night (the intensity of the main gap arc blast is insane!) Main current path electrodes are made from tungsten copper alloy (70% tungsten, 30% copper) and they are holding up very well. I can still see some machining marks at the ends. Trigger gap electrode is plain old brass screw.
1430642694 599 FT0 Gap1
1430642694 599 FT0 Gap2
1430642694 599 FT0 Gap3
Even though the trigger electrode is not in the main current path it gets hit by the arc blast so badly i will move it entirely away from the main gap area. Also next version will have different support structure and some sort of casing to countain the noise and light.
Signification
Sun Jun 14 2015, 02:01AM
I find this trigger very interesting--20v--GREAT! I need a good triggered gap for a quarter-shrinker. I would like to try this one. Is your gap exactly as in the first schematic?
Also, I was thinking about an automotive ignition coil + SCR...much lighter than NST-based. Would that work here?
I use a variac + NST + diode string that looks much like this for my HV cap charger.
hen918
Sun Jun 14 2015, 10:57AM
I have a similar TSG, made out of an old Tesla coil spark gap with an extra electrode holder glued onto it. I designed it to be used for 5/10kV pulse discharge oil filled caps, but it should be good for electrolytics.
I used a small flyback transformer and a Mazzilli driver to trigger the gap. The hot arc gives a very repeatable firing that, I think, would be even better at lower voltages and a smaller gap distance.
Ear protection is necessary!
Ash Small
Sun Jun 14 2015, 01:41PM
What diode did you use, Kizmo?
Signification
Thu Jun 18 2015, 04:57PM
Since the automotive coil has worked for me with virtually 100% success (when used with an SCR) and such simple circuit, I was wondering if there were other 'types' of ignition coils anyone else has used...i.e. motorcycle, four-wheeler, etc. I am interested in smaller and lighter.
Also, on the other end of the spectrum, where would I find a "monster" version ignition coil? (I have some REALLY tough-to-trigger laser flashlamps that have four to five foot arc lengths @ one to two cm bore! I need the "portable" 6VDC to 24VDC drive power.
This may also be useful in a homemade TSG designed for 10kVA, which uses two 1-3/4" brass spheres with adjustable gap. The trigger is simply a 4-40 (maybe a bit larger) electrode with a shiny sharp point at the end. It enters from the top. The trigger gap is threaded and placed between the similarly threaded main electrodes (1/4" brass screws) so that the trigger's point may be set ay any distance from either sphere at any height. It is all encased in heavy (1/2" lexan--about 3" x 5", 3" high). I have never used it yet. Originally for a coin-shrinker... Triggering is via an LED at 'my' end of a 6m sheathed optical fiber.
rajheman
Fri Mar 11 2016, 08:08AM
rajheman Registered Member #54872 Joined: Fri Apr 17 2015, 06:33AM
what are the rating of diodes you used kizmo ???
Kizmo
Fri Mar 11 2016, 08:43PM
rajheman wrote ...
The anti parallel diode of the main capacitor?
As large as it can be :D I think 1600V 9500A pulse. Brick style diode
