  • Guests: 44
Bead (41)
Fumeaux (25)
04/26 Bead (41)
04/26 Fumeaux (25)
04/28 Steve Conner (46)
Catching Projectiles (50J+)
1 2 3 4
DerAlbi
Sun Apr 19 2015, 02:50PM Print
Hi guys...
as i am progressing with my machine... i run into problems catching the projectile.
My setup right now is a layered setup of clay and aramid fiber sheets.. everything made hot, so the clay grips into the fiber...
This is the backside of the thing... allready repaired multiple times.
1429453467 2906 FT0 Dsc02793
This massive thing sits in 3 stacked big plastic cups.. the innermost cup is allowed to slide and pushes against foam.. this is kind of an additional energy-absorber (this actually works fine)
1429453467 2906 FT0 Dsc02794
After a shot the projectile penetrates nearly the whole clay-aramid-laminat. Its worse then you hit a spot which was hit before.
1429453467 2906 FT0 Dsc02795
When the projectile is removed, you see the initial layer of clay (which absorbs the projectile and avoids refelction) and then all the damaged layers of aramid...
1429453467 2906 FT0 Dsc02796
This is now not practical anymore to repair... it just sucks. its to weak.
Obviously what i want is...
  • a safe system which does not reflect the projectile under any condition
  • doesnt damage the projectile since they are hand made
  • absorbs the energy easily
  • easily repaired after multiple shots
I think the laminat of some elastic material and aramid is still the way to go. Its just the clay thats not good enough anymore. It gets displaced to easy and doesnt grip the fibers too well... So i am looking for alternatives.
Maybe using hot glue
This could work.. if hot enough it should grip the fibers good enough.. its flexible when cold and could withstand the impact without beeing displaced. Different layers of energy absorbtion/compressibility could be done by adding flakes of foam into the hot glue. Problem: the hot clue could be not "chewy" enough so it will damage on impact and damaged spots arent safe anymore. Unlike the clay, hotglue is not self-healing when deformed. -> damage needs to be avoided completely.
A toplayer of clay will allways be present of course... it really prevents projectile reflection very well.
Maybe using different stuff like hotglue, that are more flexible..
..but what? Silicone?
If you got ideas..... and or comments on what seem most likely to work... "shoot" wink
Dr. Slack
Sun Apr 19 2015, 04:13PM
I tend to use a *long* PVC tube, filled with stacked discs punched from corrugated cardboard. There is no chance of reflection once the projectile has bored through 500mm or more of cardboard. Increase the length until it doesn't reach the end. Retrive the projectile by pushing the discs out from one end with a broom.
DerAlbi
Sun Apr 19 2015, 04:54PM
Hmmh... thats too much work to get the projectile back... currently i just get it out with my fingers or a pair of plyers. thats kind of important to me.. since not every shot works and i want many shots in a short time when i optimize my design. i actually dont like it even now... getting the projectile out, cleaning it from the clay and inserting it again... it takes my head off the actual problem. frown
Bored Chemist
Sun Apr 19 2015, 05:15PM
A trough of water is the traditional answer, but you need to be able to point the projectile down quite steeply or it will bounce off the surface.
Of course, you could fire the shot into the side of a big bag full of water. Just make sure it's far enough away that the electrics don't get wet.
dexter
Sun Apr 19 2015, 06:14PM
i use a cardboard box filled with bubblewrap
is quite easy to stop and recover the projectile
DerAlbi
Sun Apr 19 2015, 06:31PM
I would like to focus on lamination method.. water and stuff.. thats not practical for multiple shots a minute.. i dont want to walk around the room.. its bad enough that i need to stand up from my chair at all wink ...and please.. bubble wrap.. wink How much Joule does your projectile have.. i am penetrating 1cm of plywood with ease.. anything made from cardboard is way to unsafe cry
I just added wood behind the clay.. to prevent the clay to bludge out.. however that wood disintegrated rather quick..
I think its important to catch the projectile in a increasing amount of mass. I found the wood ok.. the projectile only stuck half way in and the wood distributed the force..
Has anyone any experience in the durability of substances what would be suitable for lamination? Anything that could deform, is easy to repair, easy to work with... anything that does not get hard enough to damage the iron projectile... aaand it must not be too elastic so that the projectile doesnt reflect. However elastic deformation is prefered over the continous need to repair the target.
BigBad
Sun Apr 19 2015, 08:50PM
What's the projectile made of?
The traditional answer for stopping ballistic objects is sandbags.
DerAlbi
Sun Apr 19 2015, 10:10PM
LOL cheesey
So easy, so tempting cheesey
Projectile is made from pure iron... the only thing is that i would need a durable sand-sack.... hmmmmmh. Best one so far!
Anyone knows a good material? normal cloth will go kaputt. wink The projectile has no sharp tip, butsince its a perfect zylinder, the edges apear to be sharp.
The untreated kevlar will simply push away over time....
Maybe sand is a good backbone.. to protect the projectile tip i will maybe go with hotglue laminat. Sand will deform, but not much, so the hotglue should hold for a while... and the hiot glue will not damage the projectile. put some clay on top, and the projectile is guaranteed to stick...
did i miss something? any improvements?
Ash Small
Sun Apr 19 2015, 11:49PM
I've given this a bit of thought, around ten seconds. Dr Slack's tube appeals to me, rather than sandbags or water, and the clay seems to work, to a point.....
Fill a tube with clay, the tube stops the clay moving 'outwards'....not completely, but more so than your previous setup.
You'll still need to dig the projectile out of the clay, but as it can't displace the clay sideways as much, it won't penetrate as far.
You'll still need to re-pack the clay after each shot, but it won't penetrate as far.
Personally, I'd use a length of 2" ID scaffold tube, stuffed with clay.
Just my 2 cent's worth wink
DerAlbi
Mon Apr 20 2015, 12:10AM
Yeah.. the problem is that currently i have close to zero work retrieving the projectile. if that increased by ten-fold... its not attractive anymore.
When i try t optimize my firmare or other stuff i do not want to be distracted by the tests, i want to program, shoot, evaluate, program, shoot, evaluate.. and so on... as you see: no digging in the list wink
And debugging Coilgun-Firmware is one of the most shitty problems i came across.. since there is no slow or stepwise shot its awfull to debug. there is actually no debugging.. its eithere working or not^^ that takes a lot of concentration.
