  • Guests: 44
Jack (13)
04/25 Desmogod (48)
04/25 Alex Smith (31)
04/26 Bead (41)
Possibly the end of shootthrough in SSTC's
Teodor Zafiroski
Thu Mar 26 2015, 07:36PM
Teodor Zafiroski Registered Member #48007 Joined: Wed Jun 18 2014, 01:00PM
Anybody who has ever tried to build or actually built an SSTC, knows that half bridge and full bridge designs are prone to shoottrough. This problem becomes rather expensive when you use more expensive transistors. This problem can be solved using dead time between the turn off of one MOSFET and the turn on of the other. This forces the engineer to implement some sort of a circuit that ensures a long enough dead time to effectively protect the switching elements.
      Many gate driver chips have built in dead-time, but when using devices with slow switching speed, this dead time may not be sufficient.
      At a time, I was thinking about solving this problem for good, sort of a universal short-circuit protection for SSTC's using half and full wave inverter topologies. I came up with this (simplified) design...
Id80VTq
Here is how the two interwound coils would look in real life (again simplified).
A9del6U
Here's a schematic representation of the coil's magnetic field when the current flows through the red coil:
L1vv1XN
Here's a schematic representation of the coil's magnetic field when the current flows through the blue coil:
88NkeLh
This could be implemented in full bridge topology using a system like in this schematic.
MzNJmRP
In this case the only path the current could take is through a coil.
So, my question is:
-Could the improved half bridge schematic work, and if it could, what would happen if the two switching elements were on simultaneously?
-Could the improved full bridge schematic work, and if it could, what would happen if the four switching elements were on simultaneously?
-What an effect could the current flowing through the both coils (in both improvements) have on the rest of the schematic?
Al comments are welcome.
Wolfram
Thu Mar 26 2015, 07:59PM
This could work in a zero-current switched application like an SSTC. In cases where you don't have ZCS, the MOSFETs will have to avalanche any energy stored in the leakage inductance between L1 and L2 on every switching cycle, giving huge losses, I think. It could be an idea to add some diodes to the full bridge one, to clamp the two primaries between the supply rails during dead-time, basically making it like two magnetically coupled two-switch forward converters. This will return any energy that's stored in the leakage inductance back to the DC bus capacitor.
In the case where both switches on the same side are on at the same time, there will be something like shoot-through, but the dI/dt will be limited by the leakage inductance between the primaries.
I haven't really had much trouble with shoot-through myself, even when using GDTs. For most of my projects lately, I've used the Silabs SI823x series of isolated gate drivers, they provide a wide range of dead-time, set by a single resistor. I haven't used them in an SSTC yet, but it's only a question of time.
Teodor Zafiroski
Fri Mar 27 2015, 07:49PM
Wolfram wrote ...
I had a wild thought that the opposing magnetic fields created by the two coils would resist further flow of current. So, back to the drawing board...
omegalabs
Sat Mar 28 2015, 12:00PM
omegalabs Registered Member #1521 Joined: Thu Jun 05 2008, 10:46AM
Check out skory's mini tesla from 2005: Link
Separated primaries can work really well.
Ash Small
Mon Mar 30 2015, 04:52PM
Doesn't a full bridge become redundant with this setup?
Surely you only need one switch in each leg. You can replace the high side switches with diodes to block back EMF or whatever it's called, can't you?
You only need a full bridge when using a single coil, that's the point of it, isn't it?
Or have I missed something?
Teodor Zafiroski
Mon Mar 30 2015, 05:24PM
Yeah, I didn't thought much about that... If we simplify it, Q1 and Q2 do nothing, we can remove them, and we are left with two coils fired alternately, a design already known in the HV community. I've seen it somewhere, just don't know where...
As for the replacement with diodes, I don't think they are even needed.
And no, you haven"t missed anything...
Ash Small
Mon Mar 30 2015, 06:03PM
I think 'Centre Tapped Coil' is the word you are looking for wink
hen918
Mon Mar 30 2015, 07:47PM
They are wound in bifilar. the Q1 / Q3 side might as well be shorted together. Then you just end up with a half or full bridge driving an inductor.
Ash Small
Mon Mar 30 2015, 09:25PM
as anyone yet built a DRSSTC using a centre tapped, bifilar coil?
Ive been trying towork out a schematic in my head, I think I've got it, but not put it into CAD yet.
