Registered Member #2099
It would be quite ordinary technology if you put the 1 kg payload on a 735-metric-ton space elevator platform.
Raising the platform 10 meters in 1 hour would store 72 megajoules at a rate of 20 kilowatts. You could do it with a 27 horsepower motor, plus allowance for losses in gear train or hydraulic pump.
The Subject line in OP does not match the message body, so it's not really clear what Andy wants to do.
Registered Member #2431
Im not sure if he means the goal is to push 1kg up to orbit, but "escape velocity" in the title suggests so. theres this that basically is a solution to the energy supply-coupling-generation problem :
but its not electromagnetic...
it explosively (like RDX) fires a slug down a 90 degree barrel to compress H and O to detonation as previously said (by sulaiman), the the barrel fires at some angle upward.
Good link, Patrick, but read it more closely. That Livermore gun, and other 2-stage hypervelocity guns, use pure hydrogen between the piston and the projectile. The high-pressure, high-temperature transfer fluid needs to be (relatively) low density, thus have a high speed of sound.
The Internet shows that the SHARP gun demonstrated velocities of 3 km/s. I saw smaller ones at Caltech Geological & Planetary Science lab. A contemporary NASA design gets 1 inch pellets up to 7.5 km/s.
Gerry Bull's vertical HARP gun reached about 2 km/s and launched things into space (i.e. much higher than 100 km).
Conventional Explosively Formed Penetrators can hit around 2 km/s without any gun baggage. I wonder how much HE it takes to release 72 MJ?
Andy, why did you choose a 10 meter acceleration length? Your 1 kg projectile needs to withstand 735 metric tons of force, for acceleration of 735,000 gees. What will it be made of, and what good will it do?
klugesmith wrote ...
thats a good question, thats basically a reasonable volume of propellent or HE for an artillery shell.
YEP, wiki says...
Energy content See also: TNT equivalent Cross-sectional view of Oerlikon 20 mm cannon shells (dating from circa 1945) showing color codes for TNT and pentolite fillings
Pentolite is a high explosive used for military and civilian purposes e.g. warheads and booster charges. TNT is reported to contain 2.8 mega joules per kilogram explosive energy.[16] The actual heat of combustion is 14.5 megajoules per kilogram, which requires that some of the carbon in TNT react with atmospheric oxygen, which does not occur in the initial event.[16] The explosive energy utilized by NIST is 4184 J/g (4.184 MJ/kg).[17] The energy density of TNT is used as a reference-point for many other types of explosives, including nuclear weapons, the energy content of which is measured in kilotons (~4.184 terajoules) or megatons (~4.184 peta joules) of TNT equivalent.
For comparison, gunpowder contains 3 megajoules per kilogram, dynamite contains 7.5 megajoules per kilogram, and gasoline contains 47.2 megajoules per kilogram (though gasoline requires an oxidant, so an optimized gasoline and O2 mixture contains 10.4 megajoules per kilogram).
Chemical energy is just all-around easier to assemble and keep than electrical, we keep having this problem as humans. (drones in my case) nothing really allows rapid reliable conversion. Even fuel cells to capacitors would be a difficult scheme to muddle with.
The dual-engine Model S P85D claims 691 horsepower (515 kW). Much less than twice the single-engine rating, so maybe we are seeing a battery power limit. The car is faster than a Dodge Viper SRT10, but too heavy to beat a Lamborghini LP570-4 Super Trofeo Stradale. Compared to the 306 MJ battery capacity, that power level is what RC modelers would call a 6C discharge rate.
Andy needs his 72 MJ in less than 2 milliseconds, in fact a "2 million C" discharge rate. Too fast for chemical batteries or ultracapacitors, but ordinary for HV pulse capacitors as at NIF.
