  • Guests: 44
Nicko (56)
04/20 gentoo_daemon (42)
04/21 kilovolt (49)
04/21 wannabegeekTC (49)
Finding a Telsa coil secondary in the UK...
Sun Feb 01 2015, 08:08PM
Hey 4hv...
I'm planning on FINALLY getting around to building my first DRSSTC. Problem is I cannot seem to find any large diameter white PVC/ABS tubing suppliers in the UK... anywhere!
I've been trying to find a tube that is around 200mm diameter and 1 meters long I brought one on ebay but it was so flimsy and misshapen... I'm gonna throw it away.
Does anyone in the UK know where 'the good stuff' is?
Thanks!
dexter
Sun Feb 01 2015, 08:52PM
i used redish sewer pvc pipe and it seems to work just fine
Perezx
Mon Feb 02 2015, 02:26PM
Perezx Registered Member #54263 Joined: Thu Jan 15 2015, 09:54AM
Gray PVC tubes which are generally used for toilet water :) are very good for secondaries.
We call them "toilet tube". Diameters available are 60, 100 (or 110?) and 200 mm
Mon Feb 02 2015, 06:10PM
I can't seem to find any of the 200mm in the uk...
redruM69
Tue Feb 03 2015, 06:18PM
redruM69 Registered Member #31557 Joined: Tue Aug 06 2013, 02:38AM
Thomas W wrote ...
You wont find it in a consumer hardware store. You'll need to contact a professional plumbing pipe supply.
Tue Feb 03 2015, 06:24PM
redruM69 wrote ...
Thomas W wrote ...
I have yet to find one of those either.... Anyone know any good ones?
Ash Small
Sun Feb 08 2015, 04:00PM
Plenty of choice here: Link2
I might even go halves on a 3 metre length, Tom wink
EDIT: Including delivery, etc. it works out just under £65 for a 3 metre lrngth.
Sun Feb 08 2015, 04:50PM
Just a heads up on the 315x3000 mm pipes, its super heavy, about 10mm wall and it weighs ... 50kg+. I could barely lift it alone on my shoulder.
