Audiomodded mini-VTTC from Moscow
Perezx
Registered Member #54263
Hello guys! One small VTTC for your attention. Basefed, approx. 20 MHz, russian 6P45S (EL509) tube, 2-tube preamp with 6Zh1P (EF95) and 6P14P (EL84). 750 volts anode, approx. 45W input power. "Streamer" is about 4 cm without audiomode, 2.5-3 cm audiomodded. Windings: on the same PU core, 40mm diameter, 1mm wire, 30 turns primary and 20 turns secondary. Feedback 1 turn. Sorry for bad quality photo, only found a video and got a frame from it :)
