  • Guests: 50
David.Lightman (54)
jonny5 (40)
04/19 Nicko (56)
04/20 gentoo_daemon (42)
04/21 kilovolt (49)
12dq6b pentode vttc?
teslarevolution
Sun Sept 21 2014, 03:02AM
teslarevolution Registered Member #16903 Joined: Thu May 09 2013, 08:00PM
Hey Im getting some 12dq6b tubes from a friend and wanted to know if it's possible for them to be used in a vttc circuit. all i can find is they're pentodes and if I can't make a vttc with them, I can make a ham radio amp with them.
Mon Sept 22 2014, 03:04PM
Should work. A single tube might not give a very impressive spark, but you can stick several in parallel for more power.
Tony Matt
Mon Sept 22 2014, 07:49PM
Tony Matt Registered Member #3700 Joined: Sat Feb 19 2011, 12:59PM
Ya,
I have used two 6DQ6 pentodes in parallel final stage of a CW transmiter @ 50MHz . year of 1970.
600volts at anode, class c,
Since the frequency of your vttc is lower than 50MHz ypu may put 5 tubes or more in parallel.
teslarevolution
Thu Oct 02 2014, 12:23AM
Alright Thanks I am getting 4 of them so it should be alright!
Thu Oct 02 2014, 08:48AM
Using tubes in parallel in a VTTC you will thank yourself for making the feedback coil tap-able on the last 4-5 turns or have some high voltage potentiometers to adjust the feedback for each tube separately, else you will never get them to share load evenly.
