Registered Member #2431
Fiddy wrote ...
Sure is, with a induction heater style ZVS ive put more than ~20A at 24VDC into this flyback and its handled it.
With a 10 turn primary, 22VDC loaded @ 17A it was putting out 13.2kVAC RMS @ 28mA and has capacity for more!
I like AC flybacs too, as theres no guessing the ratings on diodes, diodes to fail, or bizarre resistors and pots hanging off the sides. But, how do you know it's 13.2kVAC and 0.028A ? This would equate to 370 watts.
If so, 13,200 v / 3,000T = 4.4 V per turn. And 22 V / 10T = 2.2 V per Turn.
so your gaining twice as much output voltage as the turns would allow in a conventional topology. Generally i like Flybacks, as we gain winding advantage, but lose on power transfer. Though in a ZVS mode maybe there's not so much power lost.
With 3000 turns with a 1 inch diameter means Pi x D = C and 3.14 x 1 = 3.14 in x 3,000T = 9,420 in of 28 awg. 28 awg = .213 ohms per meter, 9,420 in to meters = 239 meters. 239m x 0.213 ohm = 51 ohms.
so, if .028A x 51ohms = 1.4 real volts dropped by current (non reactive) 1.4 VAC x 0.028A = 0.04 watts heating in that secondary, so thats good.
have you run it long enough to judge ferrite heat accumulation?
The circuit he's using uses bipolar ZVS drive iirc so it would be +- 22V seen by the primary. Oh and he said he's inputting 374W. 40mW waste in the secondary sounds really good. As it's ZVS the primary would see only resistive losses too.
Registered Member #3414
Fiddy wrote ...
Not too sure on price as of yet, it maybe around $40USD it all depends on the bulk factor.
Then there is postage from Australia.
ZVS runs in push-pull mode, not flyback mode. You don't usually need an air gap for push-pull mode.
Patrick wrote ...
If run in flyback mode output voltage should be higher. Flyback mode doesn't depend on turns ratio. The only factor that depends on turns ratio in flyback mode is the reflected voltage seen by the primary (and the switch).
The energy stored in the airgap pushes the voltage up to whatever the load (and current) dictates. The higher the impedance of the load, the higher the voltage. A flyback (in flyback mode) is a coupled inductor, not a transformer.
