  • Guests: 31
Desmogod (48)
Alex Smith (31)
04/26 Bead (41)
04/26 Fumeaux (25)
04/28 Steve Conner (46)
CM300DY-24H Frequency
Mon Sept 01 2014, 01:55AM
I have been reading older posts on the CM300DY-24H operating frequency and opinions seems to vary on upper limits. From 70kHz to 200kHz. For this IGBT, what would be considered the max Freq (using UD2.5 driver with phase shift) at 700A peak primary current for it to run reliably with minimal heating?
Mon Sept 01 2014, 07:31AM
I'd say 100kHz would be a reasonable maximum but below 70 would be better. 200 is ridiculous.
If you want really high frequencies, try the 12NFH series instead of the 24H. The Semikron T4 series are also pretty fast.
zzz_julian_zzz
Tue Sept 02 2014, 12:48AM
I've tried personally these CM300DY-24H on a 198kHz DRSSTC,- nothing happens.. I guess, the long ON-and-OFF times cannot work with the fast switching requirement of the coil. I also tried using CM200DY-12NF series on that same coil, and it works properly., no heating has been noticed since I'm using a Phase Lead driver and at very low duty cycle (Low BPS) .
Tue Sept 02 2014, 01:39AM
Thanks guys - interesting info. I was hoping to keep the freq below 100kHz. Sounds like that is probably a good idea smile
Sun Sept 07 2014, 10:49AM
Steve, how low do you think the switching loss in a ZCS condition can be compared to 100% hard switching? I guess it can not be zero even in perfect ZCS. Maybe a ratio of something like 1:10 or 1:5? It will be worse with increasing frequency.
Mon Sept 08 2014, 09:56AM
That's quite a difficult question, which I'll answer as best I can.
First of all, there is no such thing as ZCS because the current is only zero at one point in time, but the device takes a finite amount of time to switch. If we want the switching process to complete at zero current, then we have to start it while the current is still relatively high. The higher the frequency, the higher the current we have to initiate switching.
For example, if we are running 1000A at 100kHz, the rate of change of current around the zero crossing is 1000 *2pi*100000/1e6= 628A/us.
If we say that our Powerex H series brick takes about 500ns to switch, then we will begin the switching process when the collector current is 314A.
Then, we can approximate the collector current during the switching process as a linear decay to zero. This cuts the turn-off losses by at least a factor of 2, compared to hard switching of an inductive load. In practice the factor is somewhat more than 2 because turn-off consists of a delay period followed by a fall period, and the losses occur mainly during the fall period, so they benefit from a lower current.
This then gives us the result, that for ZCS of a 1000A peak sinusoidal current at 100kHz, the turn-off loss per switching event is a bit less than one-half of the datasheet value for hard switching at 314A.
The same argument can be applied to the turn-on process with the same conclusions.
If we start the turn-off process late, then we get lower turn-off losses because the current naturally passes through zero before the switching process is complete. The problem is that the current commutates to the antiparallel diode which then undergoes forced recovery when the other bridge leg turns on. The device turning on has to handle the load current plus a large diode recovery current, so the increased turn-on losses and diode recovery losses more than cancel out the lower turn-off losses.
Tue Sept 09 2014, 07:51PM
Good point about the rate of change of the current. Thanks! smile
