  • Guests: 54
Bead (41)
Fumeaux (25)
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Capacitor Help
Fri Aug 22 2014, 01:10PM
I picked a couple of these sprague electrolytics for a power supply doubler. Have to admit, this is the first time I have seen 3 leads on an electrolytic. As the photo shows, it has a typical + and - lead on one end, and then on the other end a lead that appears to be attached to the case, but marked +.
When I apply 20v to the + and - on one end and measure the voltage between the 2 positive leads I get 18.5v. No voltage reading between the negative and far end (case) positive. Anyone have an idea of how this is connected internally? I am probably just going to use the main two leads, but was curious as to what is going on?
Cap
Fri Aug 22 2014, 01:27PM
The can of an electrolytic capacitor usually ends up about the same potential as the negative terminal, but it shouldn't be used as a connection. The third lead on these things is probably just for mechanical support when mounting it to a PCB.
Fri Aug 22 2014, 01:44PM
Perfect - that was what I was wondering. Thanks Steve for the quick response.
