  • Guests: 25
gentoo_daemon (42)
04/21 kilovolt (49)
04/21 wannabegeekTC (49)
04/21 Elijah (33)
DC Bus Caps
Aragorn
Fri Apr 11 2014, 09:01AM
Aragorn Registered Member #18516 Joined: Sat May 18 2013, 09:09AM
Rooting around the scrap pile at work i've come across a busted 7.5kw inverter.
Its casing has a nice heatsink and a capacitor module and i'm wondering if they'd be suitable for the DC bus on my DRSSTC.
The module has 6 nichicon caps rated at 1000uf 400v, as far as i can make out they're arranged in a 2x3 series parallel array, to give 1500uf at 800v. I guess ofcourse that i could remove them from the PCB and rearrange them into a different arrangement. What am i looking for to find out if these caps are suitable for the DC bus, and how much capacitance do i need here? Similar coils seem to use around 3-4000uf. Are there other specs i need to find from these caps to know if they're suitable?
They appear to be "GU" series caps, but the nichicon website doesnt list a 1000uf 400v cap in that range.
Its for an 4x18" DRSSTC with a full bridge of 60n60 bricks.
Cheers.
Fri Apr 11 2014, 03:45PM
I consider Nichicon caps to be good quality,
knowing how much they have been aged in service is difficult.
(lots of experienced guys at work - no clear consensus)
First, remove the capacitors to check for
erosion of the pcb or signs that the vent (pip) has operated = fail.
weight (presumably electrolyte) loss = fail (e.g. 1 of 6 feels 'light')
high leakage current or capacitance loss can indicate a 'weak' unit,
high esr is a good indicator of end of service life
esr meters are a bit specialist, so if a cap looks and feels ok, it probably is.
At work, our standard repair for drives (inverters) is to replace all small aluminium electrolytics and test the Bus Caps.
Warranties are bad for our business but drives run for decades, during which time the same drive may be repaired more than once but the Bus Caps generally outlive the drives.
check and clean the bus cap pcb.
P.S. the output stages are all fairly similar,
pwm relying on motor (or additional) inductance to produce sine wave motor current. Some have interesting gate drivers.
Dr. Slack
Fri Apr 11 2014, 03:52PM
Don't get too uptight about an initially high 'leakage' current. Electrolytics, especially if they've been sitting around a long time, and especially if you're charging them to a higher voltage than they were used for before, can take quite a high reforming current for quite a while before they settle down. Though if one is much longer than the other 5, it's not a good sign for that one.
Aragorn
Fri Apr 11 2014, 09:20PM
Thanks.
I dont really know what went wrong with this inverter, so i guess the caps may or may not be knackered. The electronics guy reconned at least one of the IGBT's had popped. PCB was dated 2007, so its not new, but not mega ancient either.
I tried sticking a multimeter on capacitance mode across the PCB terminals, but it didnt do anything, however i noted that there appear to be a pair of resistors soldered across the PCB planes, so i guess those were probably causing issue with the readings.
The PCB itself is in perfect condition, and the caps dont look swolen or damaged at all, so i'm hoping they're ok. Even if i got 3 or 4 of the 6 working that would be fine i think.
I'm off on holiday next week, but when i'm back in i will try to desolder the caps from the board and test them. Not sure if we have an ESR meter, might be one knocking around.
