  • Guests: 40
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
TDU Microwave/Telsa prize
1 2 3 4  last
Tesladownunder
Thu Aug 31 2006, 04:38PM Print
Ok, I reckon that there is not enough ingenuity and resourcefulness going on in budget coiling these days.
I propose a prize of $US 50 to be paid by PayPal by me to the person who makes a Tesla coil with the longest sparks from a standard microwave oven.
Conditions:
This is meant to be fun
One standard domestic MO (microwave oven) less than 1000W to be obtained free.
MO must be the transformer type not the inverter type.
Only the parts of one oven to be used. No other parts to be used apart from solder, hot glue or epoxy in reasonable amounts (not large amounts to make secondary formers).
This also means no PVC, tape, paper or other extraneous substance.
How you adapt the internal parts is up to you.
Progress, results and sparks must all be photographed to confirm use of only parts of one MO are used. Spark length measured from the photo with a ruler adjacent.
Enter as many times as you wish
If you think you might be bending the rules in some way post your question or PM me if it is confidential.
I will be the sole judge (possibly - may be a group vote is best)
Competition closes December 1 2006.
And you thought that was hard. The hardest thing is that you will be competing with me who doesn't want to lose his money!
I expect the useful parts to be the 2000V transformer, 1uF mylar capacitor, 10kV diode, fan, wires and round glass plate. Also turntable motor, low voltage transformer etc.
Clearly none of these parts are ideal at all and would normally not be associated with coiling.
I reckon they can make a successful coil with a 1 or more inch spark at zero cost but you need to think outside the box here. I have a lot of ideas and have done some preliminary work.
Comments?
Peter
Thu Aug 31 2006, 05:06PM
This sounds like a great challange, I will begin my hunt for a <1000w microwave. I have a 1100 in the basement but there is a blunk garbage pick up soon so I will find one shortly.
ReddyK
Thu Aug 31 2006, 05:25PM
ReddyK Registered Member #92 Joined: Thu Feb 09 2006, 03:11PM
I like this! Can I assume that the use of a variac is ok?
Steve
Tesladownunder
Thu Aug 31 2006, 05:49PM
Variac from the mains seems OK. I can think of some creative cheating by using 15kV as the power source but a variac should be no problem. I don't think you will need to turn it down much though rolleyes
Peter
EDIT Sorry, I have had a rethink on this. I think it is an expensive add-on that does not enhance the project. So no variac, sorry.
Thu Aug 31 2006, 07:07PM
Will you makes alowances on things like marrets (screw on wire connectors) for joints? I would rather not have all my joints laying around and exposed while the thing is plugged in.
Electroholic
Thu Aug 31 2006, 07:15PM
sounds fun, i will begin my hunt
Roger
Thu Aug 31 2006, 09:04PM
Roger Registered Member #221 Joined: Mon Feb 20 2006, 05:36PM
This sounds like fun. I normally power my larger coil with two microwave oven transformers but I cant really tell what my maximum spark length would be because my garage isn't big enough. If I set it up to run with just one MOT maybe I can tell. Ops, I just took a closer look at the rules of the contest. Now I see that every thing has to come from just one microwave oven. That might be a little harder.
Roger
Marko
Thu Aug 31 2006, 09:12PM
I think most interesting part is going to be finding wire and something to wind the secondary around. Wire may come from a relay or something (if there is any) but the form is tricky thing smile
Making spark gap that is going to work with 2 kV is also going to be challenging, we may see some new ideas over there..
I unfortunately can't get a MO for myself but challenge is very interesting anyway..
Thu Aug 31 2006, 09:16PM
fan motor may help for some sort of rotary
Thats what I thought too but it is also a VERY good source for secondary wire. I wish I still had that 80's microwave. It had a 4kv reed switch in it.
JimG
Thu Aug 31 2006, 09:44PM
JimG Registered Member #52 Joined: Thu Feb 09 2006, 04:22AM
In the few microwaves that I've pulled apart the fans have had magnet wire that was easy to remove.
1 2 3 4  last
