Python source thread
Dr. Slack
Registered Member #72
Module for arbitrary quantisation of numbers ]nicenum_py.txt[/file]
Dr. Slack
Wrapper for PyAudio (which itself uses the common PortAudio library) to give non-blocking I/O, and both sync and async access to native Python types
rename the name_py.txt file as name.py ]audioio_py.txt[/file]
Dr. Slack
Trivial multichannel oscillator class, uses for testing audioIO
rename the file name_py.txt to name.py ]tonegen_py.txt[/file]
Dr. Slack
Multi-component 2 channel signal generator
rename file name_py.txt as name.py ]sig_gen_003_py.txt[/file]
