  • Guests: 28
GrantX (34)
03/29 GrantX (34)
03/30 Adam Horden (39)
03/30 Mr.Warwickshire (23)
Mini induction heater IRFP460 5 MHz
zilipoper
Tue Jul 24 2012, 03:15PM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
Hi this is my Mini induction heater made in 20 minutes cheesey
without load, he does not consume power tongue
he does not explode, when 50V strongly bask capacitors amazed
scheme
1343142837 4152 FT0 Sam 1728
Tue Jul 24 2012, 05:06PM
очень хорошо! Thanks for posting the schematic smile
zilipoper
Tue Jul 24 2012, 05:43PM
thank you shades
1343151826 4152 FT142264 3243 1343150063
Chip Fixes
Tue Jul 24 2012, 09:17PM
Ah this is awesome! What was your input voltage? and what's a good wire to use for the coil?
Gabriel35
Tue Jul 24 2012, 11:14PM
Gabriel35 Registered Member #2310 Joined: Wed Aug 19 2009, 08:04PM
How much power it can handle?
I mean, how much voltage is safe to put on "+U"?
Does the potentiometer controls the frequency?
Does it take feedback directly from the coil?
Interesting Schematic, i've never seen a so simple driver before...
kimbomba
Tue Jul 24 2012, 11:26PM
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
Very nice result. What is the voltage rating on the capacitors? Is D1 a zener? thanks for sharing.
zilipoper
Wed Jul 25 2012, 06:16AM
D1- zener. supply voltage I had 40-50V
The higher the voltage, the more heated coil and capacitors smile
Gabriel35
Wed Jul 25 2012, 04:24PM
How much voltage is safe to put on "+U"?
kimbomba
Wed Jul 25 2012, 06:35PM
What is the type and voltage rating of you capacitors? how many turns you have for feedback?
Chip Fixes
Wed Jul 25 2012, 07:40PM
Will it at least melt solder with 24v? I just built one but I don't have a variac :P
