  • Guests: 15
GrantX (34)
03/30 Adam Horden (39)
03/30 Mr.Warwickshire (23)
03/31 Swedish Coiler (41)
Kaizer DRSSTC III
Thu Jan 19 2012, 05:46PM Print
Project website with all photoes: Link2
Specifications (incomplete due to some future minor changes)
Bridge: 2x CM600DU-24FA IGBTs in a full bridge configuration
Bridge supply: Full wave rectified 3x400VAC, 4x 6000uF 350V filtering capacitors, two in series, two string in parallel for 6000uF at 700V.
Primary coil: 8 turns, flat primary.
MMC: 5 in series 4uF GTO snubber capacitors, rated at 3kV / 5kA peak for 0,8uF at 15kV.
Secondary coil: 315 mm diameter, 1500 mm long, 2200 windings, 0,75 mm enamelled copper wire.
Topload: 7 rings of 25 mm aluminium tubing.
Resonant frequency: Around 38 kHz.
My first attempt on building a large DRSSTC, it is a costly affair and I have chosen to go the high impedance way, mostly for the cost reason, going low just is expensive :)
TODO LIST:
Finish enclosure
Tune for maximum power
COMPLETED LIST:
Gathering all parts
Winding secondary coil
Build enclosure
Build primary coil
Build driver
Build bridge
Test driver
Test bridge
Finish secondary coil with end caps
Build topload
Finish primary
Test bridge
24th December 2011
Actually construction on the coil begins, secondary coil is wound in a mere 3 hours with a brand new and much more stable winding rig than the old I had. 7 layers of varnish was applied over the next week.
1326994690 1403 FT1630 Img 6150
1326994809 1403 FT1630 Img 6158
1326994809 1403 FT1630 Img 6164
29th December 2011
Making of primary supports from 10 and 12 mm acryllic from LCD monitors begin, a good week later they are finished and ready to be mounted on the primary base. The acryllic was almost rock hard to work with and splintered very easy, to our huge disappointment they cracked like nothing after drilling holes to mount them. We suspect it is either tensions from the milling or the acryllic type, cast, extruded, we dont know. We just lost many hours work in this.
1326994690 1403 FT1630 Img 6081
1326994690 1403 FT1630 Img 6084
1326994690 1403 FT1630 Img 6088
1326994809 1403 FT1630 Img 6162
14th May 2012
When I first found these pieces of scrap PVC, my first thought was to use the already made holes to put the leads through and distance the capacitors that way. But recalling that Finn Hammer made a fishbone like skeleton fos his MMC, I tried something like it and ended up using all the plastic, even the cut outs that is used for the backbone. The end terminals of 20×10 mm copper is overkill, but was what the scrapyard had at hand that day, they do however make a good connection in the sides for the capacitor strings.
The result is half of the MMC is completed. 0,2uF at 12kV. The completed MMC will be 0,4uF at 12kV.
1337452099 1403 FT1630 Img 6680
1337452100 1403 FT1630 Img 6684
17th May 2012
New primary supports was made from scrap PVC, I found some good pieces of 20 mm thick PVC to use for these.
1337452100 1403 FT1630 Img 6688
18th May 2012
The enclosure have been put together with wheel mounted, the primary platform is raised from the enclosure to allow for taking the complete Tesla coil apart, make connections of cables and possible water cooling easier and to gain distance to metal objects in respect to the primary coil.
The enclosure and primary platform is entirely put together with only glue and wooden nails, nearest metal in the current construction is the wheels at the bottom.
1337452100 1403 FT1630 Img 6705
6th October 2012
Copper bus bars for the bridge and spacers for capacitor mounting machined and milled. 260 mm² copper bars are used for the DC connection with the capacitors.
1352972614 1403 FT1630 Gs6a8990
20th October 2012
Material for topload toroid construction was bought cheap from the scrap yard. 7 large rings of 25 mm diameter coaxial antenna cable, aluminium shield with PE foam filling and copper tubing core.
IGBTs mounted on heat sink, support for capacitors constructed and capacitors mounted on IGBTs. Construction of 3 phase rectifier bridge on heat sink and preparing mounting on the bridge supports.
1352972614 1403 FT1630 Gs6a9010
3rd November 2012
Finished installation of wheels on the enclosure and secondary coil was sawn over in both ends to get the right secondary tube length.
10th November 2012
Winding of the two GDTs, etching of gate PCBs and soldering of the gate PCBs and the GDTs.
Mounted 3 phase bridge rectifier, DC cables, snubber capacitors and TVS strings.
All the busbar work have been done, in 30×10 mm copper and brass.
The new MMC consisting of 5x 4 uF at 3 kVDC for 0,8 uF at 15 kVDC have been installed with the bridge.
1369746338 1403 FT1630 Gs6a0463
1369746337 1403 FT1630 Gs6a0464
1st May 2013
Bench test of driver was carried out. This is Steve Wards universal driver 2.1 converted to single sided board for through hole components only. Still some bugs and misroutings that was worked out during the test. The pulsewidth limiting network was bridged over as it caused some oscillations that made the driver turn the output on dispite no input from the interuptor.
1369746338 1403 FT1630 Gs6a0471
21st August 2013
Construction of primary tap. It is made from a old clamp from mains distribution lines. 3x 35mm^2 is used.
1397761919 1403 FT1630 Gs6a1904 Custom
1397761919 1403 FT1630 Gs6a1907 Custom
1397761919 1403 FT1630 Gs6a1908 Custom
Fall 2013
I had the same problem with my phase lead driver as Kizmo describes and troubleshoots in this thread: Link2
Due to travelling around Europe as my job I had very little time to partake in the fault finding, Sync was kind enough to have my driver send to him and test it out. He found no problems and meanwhile the solution was found in Kizmo's thread.
Residual charge in the MMC can give the driver a false start. The solution is adding bleeder resistors to the MMC, but as we use large GTO snubber capacitors they have to have the same rating, an easy workaround is to place the bleeder resistor across the inverter output and burn the charge through the primary coil, thus the voltage rating only need to be that of the inverter output.
17th April 2014
First test where the CM600 bridge is running stable was conducted. At around 270VDC it is running 1000 Apeak over 240uS ontime. Yellow trace is primary current, 500A/div and blue is inverter voltage output, 250V/div.
Static load test on a metal bucket with water in.
 1ka Test
20th April 2014
At around 320VDC it is running 1500 Apeak over 300uS ontime. Yellow trace is primary current, 500A/div and blue is inverter voltage output, 250V/div.
12th July 2015
It has been a long while without progress, mainly due to being a small family takes time from the hobby :)
A good while also lasted to have the topload arms waterjet cutted at a reasonable price when there was a job with spare material at the cutter.
The rings was rolled on a quick mockup for a motorized tubing roller that could easily bend the soft coaxial antenna cable used.
1436937581 1403 FT1630 Gs6a8987
1436937581 1403 FT1630 Gs6a7964
We assembled the rings and arms with rivets from the inside, unfortunately the thin walled aluminium shielding of the cable was not as strong as anticipated and it would let go of the rivets in several places, we had to cable tie it all together just so that no more would let go. Which kind of final solution we find or it will just be ties, no idea yet.
1436937581 1403 FT1630 Gs6a8019
1436937581 1403 FT1630 Gs6a8029
1436937581 1403 FT1630 Gs6a7975
Secondary coil end terminations and topload insert mount
1436937581 1403 FT1630 Gs6a7993
1436937581 1403 FT1630 Gs6a8030
Topload sitting on top of the secondary coil
1436937581 1403 FT1630 Gs6a7987
Next job to be done is finishing up the enclosure and primary coil platform, painting, mounts for putting it all on top of each other with splits, water cooling for the primary coil. :)
24th January 2016
A 32A CEE plug is used for 3 phase mains input connection, we only used the plug itself and made a custom fitting for it.
1453899460 1403 FT132685 Gs6a9739
The split that holds the secondary in place.
1453899460 1403 FT132685 Gs6a9740
Coiler and coil :)
1453899460 1403 FT132685 Gs6a9748
Test setup outside of the garage
1453899460 1403 FT132685 Gs6a9750
First light test and it was unfortunately under horrible conditions. We finished all the cabling and other small parts, bits and missing stuff in a days hectic work that lasted all night. So we missed the opportunity of testing in darkness.
There was no tuning performed due to lack of time, input was limited by a smaller 6A variac, BPS was kept down for the same reason, it was broad day light, foggy and wet day, the coil was just pushed outside of the garage and no cables was long enough to get it further away from the tree/house.
Sparks are about 60-70 cm and we killed the LED christmas light chain that was in the tree, it was unplugged before we started, but left the LEDs black rather than clear white.
31st March 2016
11
Like the first test, we were once again only able to test in the early evening due to noise in the neighborhood.
There was no tuning performed due to lack of time.
The big surprise was however that we ran on the same 6A 3 phase variac as last time, and it did not heat/or scream one bit from the runs shown in the video + a handful more.
The supply for the variac is only a 3x400VAC fused at 16A, the OCD set at 1500A never tripped even once, running BPS up to 350, 200uS on-time and ground strikes. Power meter gave an average of 0.75 power factor for our total runs.
This was a triumph!
I'm making a note here:
Huge success!
It's hard to overstate
my satisfaction.
10th September 2016
I have cut out the bonding wires to the RTC circuit of the CM600-24FA IGBT bricks, which we thought could be one of the reasons that we were not able to trip the 1500 A OCD setting. While it might have limited the operation a little bit, it was nowhere near hindering performance, this coil is just so high impedance that it runs long on-times instead of high peak currents.
Fed with 3x400VAC through a variac resulted in a 0.6 power factor. After roughly 8-10 test runs at up to 2 minutes, with peak power consumption hitting 14 kW at 500 BPS, 200uS, the total power consumption over all the tests was 0.281 kW/h, 0.331 kVAr/h and 0.481 kVA/h.
Heating up a 3 mm iron plate with some high BPS
Playing a MIDI, Bach - Tocatta Fugue, on the 3 mm iron plate
Full power, all that we could pull from the wall and let it run, 120-500 BPS at 200 to 300 uS on-time. Peak consumption is again around 14 kW.
Wolfram
Thu Jan 19 2012, 06:06PM
Mads Barnkob wrote ...
MMC: Cornell Dubilier (CDE) 942C20P15K-F
Don't do this unless you already have the capacitors. They are simply way off for big DRSSTCs, with way too much peak current handling capacity in relation to the capacitance and RMS voltage rating. What I mean is, if you design it for the RMS voltage handling you need, the RMS and peak current ratings will be many times what you need. Which isn't a problem in itself, but the current handling is what you're paying for with these caps. So you will end up with a cap bank costing thousands of dollars if you want a sensible voltage rating. You can always exceed the datasheet voltage rating, but you'll sacrifice reliability and still pay more than if you chose some more suited caps to begin with (and then you won't even have to exceed any of the ratings).
Many standard metallized polypropylene film caps will work fine in big DRSSTCs, some people state that only the 942C series are good enough for TCs, but this is in cases where the caps are pushed so far beyond their ratings that it's a wonder they survive at all. The wonderfull thing about large DRSSTCs, especially low impedance ones, is that a proper MMC can be made for not very much money if you chose the right caps. You can even design the MMC so that you don't have to exceed ANY datasheet ratings without it costing a fortune, and reliability will be guaranteed.
Look at the biggest DRSSTCs, most of them use other capacitors than 942Cs.
Edit: forgot to mention, very nice work. Looks solid.
Sat May 19 2012, 06:51PM
Finally it is time for an update on this project, read it all in the first post of the thread! All the detailed construction pictures can found on my website.
Wolfram wrote ...
Thanks and I am well aware that the 942C is less ideal for a large DRSSTC, but money rules in some of the decisions. I have looked at multiply alternatives with snubber caps, large mica caps from transmitters etc. all would be many times more expensive than buy the few more 942Cs I would need.
Thu Nov 15 2012, 09:52AM
Time passes by and a lot of things have changed and not so much have been built :)
I have upgraded the planned CM300 brigde to CM600 as I came by some reasonble priced ones.
Material for the 7 ring topload was found incredible cheap.
MMC have been upgraded from 96 pieces of CDE942C capacitors to a massive GTO snubber capacitor mmc consisting of 5 in series 4uF/3kV/5kA peak capacitors.
Bridge is finished and need only gate boards and GDT mounted. Next up is getting the driver board done, tested and bridge testing can begin.
As always all pictures can be seen here: Link2
Bennem
Thu Nov 15 2012, 11:56AM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Very nice work!
love your construction pictures too.
All these large DRSSTCs just make me wanna build one.
just need a little thing called 'funds'.....lol
All the best with your continued build and look forward to seeing its sparks.
Mel.
Tue May 28 2013, 01:39PM
Time flies by and the work done is little compared against the time line, but I shall get there some day!
Main post updated with pictures and rest is to be found on my site.
Thu Apr 17 2014, 07:03PM
Main thread have been updated with fault finding explanation, primary tap construction and static test of inverter.
Wed Jul 15 2015, 05:30AM
Updated main post at the top with new progress from 12th July 2015 :)
Intra
Thu Jul 16 2015, 11:50AM
Intra Registered Member #2694 Joined: Mon Feb 22 2010, 11:52PM
Hi Mads,
Good job!
Looks like upper copper wire between coil and toroid plate are extremely tiny for current it will have. Eric Goodchild had a problem with that and he remade it from tiny wire to copper bus.
Thu Jul 16 2015, 01:06PM
Intra wrote ...
Hi Mads,
Good job!
Thank you Intra.
It is just the continuation of the secondary wire, it is a 0.75 mm copper wire, it is carefully put in a slit to avoid sharp edges where break out might occur. Is the secondary circuit current distribution really so that the last 30 cm of wire carries more current than other parts of the coil?
